- English
- Cameras
- arlo base station showing solid amber light on cam...
arlo base station showing solid amber light on camera icon
Arlo base station showing solid amber light on the camera icon
Rebooted Arlo base station to the factory twice
Arlo application not detecting cameras and Arlo base
Internet is connected to the Arlo base station showing green light
Please help
Just confirm that the base station camera LED is showing steady amber correct?
If so it suggests that one or more cameras are not connected to the base station.
Could be the camera battery/s are flat. Have you charged them?
What was the initial problem?
Actually, a solid amber Camera LED means the base needs to be claimed again. Try using the Add Device selection in the Devices card to add the base back in. If having problems, you may need to delete all devices from your account and start fresh.
Thanks for pointing that out regarding the steady amber camera led on the base being an unclaimed condition.
It seems a shame that arlo’s multiple documentation and articles are not a reliable information source as they state otherwise for the led conditions.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
