Why is it filming in pink? I've restarted it and turned it off and on...
Sounds like the IR filter for night vision is stuck. You can try carefully using one hand to hold the camera and hit the back of the camera into your other hand to see if that helps. If not or it keeps happening, use Settings, Support (Center) to choose your camera model and contact official support. You need a subscription of any sort to use this.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
