VMC2030 not connecting
  • 15 Replies
  • 6970 Views
  • 6 In Conversation
ZarbiZarbi
one of my two brand new Arlo essential spotlight fails to connect to any wifi. Process always terminates with the orange led blinking fast in the last phase when searching caméra. Any hint?
15 REPLIES 15
ZarbiZarbi
Thank you @jguerdat
I will not do a reset myself because i purchased the camera through Verisure and it is associated to a specific provider account which will be lost upon reset. Then it would require a full reinstall of my sécurité system by Verisure. Sad but true… 😭😭
Fatime23
My back camera not working, I did see it in my phone, even it’s charger
ShayneS
@Fatime23
Is the camera offline? May I ask which troubleshooting steps you have performed so far? I don't want to suggest anything you have previously performed.
Paulmidi
My arlo Essential spotlight  camera stopped working I deleted it and tried to add a new camera I have pressed the reset button for 15 second's It searches and never finds my camera.
I have tried to add the camera from only a few feet from the base station I have tried everything I can think Of.
Please help!
PS isn't it strange this camera stopped working one year to the day that I bought it?
Have you tried adding the camera using a PC (my.arlo.com) instead of using the app?
Make sure you are choosing the Essential Spotlight when you add device - not just Essential.
Paulmidi
I have gone to my PC and tried to login to Arlo I am sent an authorization code
the problem is there is no place to enter the authorization code in.
What is going on?
ShayneS
@Paulmidi
Have you tried clearing your websites cache?
Paulmidi
no I haven't.  I am at a loss!
@Paulmidi wrote:
no I haven't.
Then try that next (google how to do it with your browser if you aren't sure).
Or try opening a private/incognito window in the browser, and log in from there.
Paulmidi
I wanted to correct myself the camera didn't stop working one year to the day I looked up the information I bought it in May of 2022 so it lasted maybe 5 months.
The amazon store it came from pretty much says to bad for you.  I love arlo but I will only buy the expensive ones in the future.  This was the first inexpensive one I have bought I should have known better.
5 months is still within the 1 year warranty period. Use Settings, Support for a possible RMA.
Paulmidi
I looked it up it says purchased on May 6, 2022 and the return window closed on June 7, 2022 what’s that about 30 days?
I did contact the seller they pretty much said there’s nothing they can do.
I wanted to thank everyone who’s been replying to me over this saga.
ZarbiZarbi
@Paulmidi On my side, the reseller came to replace the faulty camera. All fine now.
Seems you didn't act on my suggestion to contact support for an RMA under the warranty.
