- Is it possible to use same credentials on two different VMB3000 base stations at a time? This is to try screaming 10 ccamers together. Any suggestions to do so?
Message 1 of 2
1,122
Yes. You can add as many base stations or SmartHubs as you wish but only 5 cameras per base/hub will be able to stream simultaneously. Of course, that assumes you have adequate upload speeds from your ISP.
Message 2 of 2
1,084
Message 2 of 2
1,085
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
