VMB3000 Base station
  • 1 Reply
  • 1255 Views
Rajesh-p-kurian
  • Is it possible  to use same credentials on two different VMB3000 base stations at a time? This is to try  screaming 10 ccamers together. Any suggestions to do so?
Yes. You can add as many base stations or SmartHubs as you wish but only 5 cameras per base/hub will be able to stream simultaneously. Of course, that assumes you have adequate upload speeds from your ISP.
