serial # AB622C7HD019E Firmware: 1.090.32.1_55_07e3402
Will not charge on ac charger or solar panel.
Worked until battery died and now nothing..
Is there a warranty or solution?
Purchased: Arlo direct order number #10458595
Purchase date: February 16, 2023
You're out of the warranty period for many regions but I'd still try using the app to go to Settings, Support and select your camera. Scroll down to Contacts to talk to official support to see what they say.
In the meantime, you can try this (which may or may not help):
https://kb.arlo.com/000052305/My-Arlo-Pro-or-Arlo-Pro-2-battery-is-dead-what-do-I-do
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
