Too many cameras?
  • 1 Reply
  • 1238 Views
Daveisgreat
I have 10 cameras, half in the U.K. and half in the USA. When the USA cameras are armed I do not see recordings in the library from the U.K. cameras. If I disarm the USA cameras then the next time I look I see U.K. recordings in the library, only for the time the USA cameras are disarmed. Is the Arlo cloud bandwidth constrained? Can my library only accept a limited number of recordings? Obviously the two sets of cameras are on separate local LANs each of Gb/s bandwidth. What’s going on?
I'm not sure what's going on here but are you using the old user interface (UI) that uses Library to view videos or the new one that uses Feed? With the new UI, you would have 2 Home entries due to the different locations. Each Home requires a subscription of its own and you would click on Home to choose the proper Home for the location. Renaming them would be useful to help determine which is which.
