Spotlight pulse setting not working
On arlo secure trial and pulse and dim toggles do not work. Any ideas?
AJV1,
Could you provide more details about what you're experiencing? Do you have a screenshot?
Hi James,
On the app I go into spotlight and set the toggle to pulsate. It makes no difference, the spotlight comes on constant. Similarly with dimming. I have 2 spots which are the same. Is it because I am only on the secure trial?
Adrian
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
