- English
- Cameras
- Solved: Arlo Essential camera failed to reconnect ...
Solved: Arlo Essential camera failed to reconnect to wifi
While on a trip, my ISP had a glitch, and my modem/router rebooted spontaneously. Two out of my three Arlo devices automatically reconnected to the second router/wifi connected to my modem/router. One did not.
To get the disconnected camera to reconnect, I used the management app for my second router to force a remote reboot. Then, all three of my Arlo devices reconnected to it.
This tip has more general applicability: past experience with failure to reconnect an Arlo camera is that if removing and reinstalling the camera does not work, then you should try a reboot of your wifi/router.
Apparently Arlo's knowledge base does not know about this tip.
Note also that if your wifi/router is set to admit only known connections, then doing a reset/reinstall of an Arlo device will give it a new identity which your wifi/router may not allow until you give permission.
W9VK,
This is helpful information for others who may experience a similar scenario. Thanks for sharing with the community.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
