I recently ended my Verisure subscription. I am trying to install doorbell even after scanning QR code it just can’t find the device.
I have closed all cellular data, vpn, extender etc whatever can result interference. So my phone app and Arlo camera is connected on the same 2.4 network for sure.
I have factory reset the doorbell. But the app is finding the device.
I don’t have a separate Arlo sub, could that be the issue? Detaching from Verisure could have some side effects? Could you help me out please to reinstall the doorbell?
I don't know what the process is to remove Verisure and switch to Arlo but the first question is always, did you remove the camera from your Verisure account? If it is somehow in an account you can't add it again. You may need to contact Verisure to see if they can tell and perhaps remove it for you.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
