Push notification question
  • 2302 Views
Tonytigerjunior
I have 2 arlo esentials cameras. Did Arlo corporation  take away the push notifications in order for citizens buy more expensive cameras?  Its like sayin cars that are over 8 years old should be disposed of. This is one of the worst cases of greed in my lifetime!Hopefully others like myself feel this companies abuse upon whom place food in their tables. I cannot adjust all 3 cameras either. Donot support this company anymore! Buy somewhere else. I will do so.
No, they haven't removed push notifications for any cameras.
Tonytigerjunior
Thank you i got a notification that the end of the line for  Arlo essential  cameras like mine, that push notifications might not work. Or other services.
Arlo essential cameras are NOT on the end-of-life list. So if you received the EOL notice, you should double-check the camera models that you own.  There are a couple of ways to do that.  One is go into the support area of the app, select the camera, and scroll down to the bottom and look at the product id field here.  Note that the "H" number you might see in the device info in the camera settings is not helpful - you need to go into the support area.
Arlo won't support EOL cameras, and is not promising that services will work indefinitely.  But they have said here that they won't intentionally disrupt the services either.
