- English
- Cameras
- Re: No videos being stored in library, have active...
I noticed today at work that I was not receiving messages of activity from my camera such as wife and kids leaving for school, the mail man, usual stuff that the camera picks up. Had one video from 2 days ago in my library. When I left for work this morning the camera came on like it usually does so it seemed like it was working. Checked the live video when I noticed no alerts and the camera seems to be working but went ahead and reset it anyway, live video still works but no recordings in my library besides the one from a couple days ago. Came home from work and got on my computer trying to see if it was the app on my phone acting up, tried logging in but the 2 part authentication would not send to my phone, had to switch to email for the authentication to work. After logging in I am still having the same issue as using the phone app. Iphone 11 if that helps. I'm kinda dumb but I can usually figure this stuff out, think the problem may not be on my end.
Fixed, Deleted it all. Fresh install seemed to work. The battery was at 45% on the camera but I went ahead and put it on the charger, tried synching it to my network and the camera would never connect. Disconnected the charger and bingo it synched up to the network. Also had to change some settings to direct my Arlo secure subscription to the camera, guess it sees it as a new device.
Can you make a manual recording when you live stream a camera?
@CoryCal wrote:
Yes, just tried recording the live stream and it popped up in my library. Still nothing comes to the library when the camera is motion activated
Ok. This does confirm that the problem isn't linked to the subscription.
Have you checked the current mode (making sure the camera is armed)?
Are you using geofencing or scheduling?
@CoryCal wrote:
The camera is still turning on when it senses motion
Have you tried the motion detection test? https://kb.arlo.com/41/How-do-I-change-the-motion-sensitivity-on-my-Arlo-camera
Might also be worth looking into the rules in the Armed mode, just ot make sure recordings and notifications are enabled on the rules.
If you are using activity zones, then I'd also suggest deleting them and see if that makes any difference.
CoryCal,
Are you able to live stream and manually record? Do those recordings arrive in the library?
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
