No connection to app with LTE internet
  • 2 Replies
  • 1753 Views
physioprofit
Why I can not login to Arlo app with very strong LTE internet?
What phone/OS ?
Does it work on wifi ?
do you have a subscription on camera ? either way you should be able to live stream
Maybe check the app settings, and make sure it is enabled for cellular data.  With iOS that is controlled via the main settings app for the phone - you scroll down to the app in the list, and then select it.  There's a similar setting for Android, but I don't recall where it is.
