My spotlight gets confused....
Hi,
Very satisfied with Arlo and just upgraded to the Spotlight version.
Spotlight turns on allright while dark, but sitting at the maindoor, and if you walk in and out a few times, the camera gets confused, and forgets to turn off the spotlight. This means that battery is drained within a few hours.
Guess this requires a alteration of FW or other suggestions ?
Thanks in advance 😉
Start by removing the camera from Settings, My Devices and reconnect it. Any better?
Sorry, problem is still the same after removing and re-installation - I guess that this needs some kind of FW-update.
Best regards,
Kim
Use the Contact Support link at the bottom here for a hardware problem.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
