  • 2 Replies
  • 1563 Views
Arlo-721
My camerras are offline. Is it possible to reconnect them for me? Thanks.
If you camera are truly offline, you can NOT reconnect them remotely.
Easiest thing to do is try to re-sync them.
You can try contacting support (using the support area in the app).  They can't directly reconnect them, but they can help you do that.  If you want to try on your own, the reset procedure is here:
Although the procedure says to release sync on the Essential when the camera blinks blue, I suggest instead waiting until it blinks amber.
Have you checked that the cameras are charged?
