- English
- Cameras
- Re: More low battery issues - Arlo is only 9 month...
I charged my Arlo and took it off the charger fully charged at 11:51 am yesterday. It recorded 14 events, 15-20 seconds each - was not otherwise in use and I was very careful when putting it back up that it only can see motion in my driveway and no other cars or people. These events were all in daylight so the light was not even on. As of 4:00 am this morning it went to 14% battery. This has a very strong signal to my router. I have it set to optimized battery life. When I got this camera in December it went 6 weeks between charge. This all changed with the firmware update in July. I am begging you to roll back to the old firmware. There is a big, big problem here. The camera and my subscription are essentially useless now.
Is this happening consistently (daily occurrence)? Are you able to easily reproduce this issue?
Are you using Activity Zones?
Try removing and re-onboarding the camera.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
