Looking for a surveillance camera
Hi
I'm looking for 4K, >4MP, WiFi, Solar Panel and 25 FPS outdoor surveillance cameras.
Do you have any with similar features?
The closest are the Ultras which require use of a SmartHub. They're 4k but not 25 FPS. They do use WiFi but it's with the hub. Otherwise, the Pro5S is 2k but still not 25 FPS. These do allow use of WiFi.
I suspect these aren't appropriate for your usage.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
