In you Mode then Rules each camera. You can set until motion stops or for up to 120 seconds.
My essential will not record to the thumb drive on the base station or show clips in the app. The other older Arlo cams show the clips in the app. I dont have cloud recording. The Essential cam DOES generated notifications but will not record a clip to thumb drive. I have already disconnected it and reconnected it.
@jaward11 wrote:My essential will not record to the thumb drive on the base station or show clips in the app. The other older Arlo cams show the clips in the app. I dont have cloud recording. The Essential cam DOES generated notifications but will not record a clip to thumb drive. I have already disconnected it and reconnected it.
For Local storage on you Thumb Drive on the 4000 base you listed you must eject it the drive and view it in a computer, you can only see Local recordings in the App on the Smart Hubs.
You are seeing Cloud recordings in the app for the older ones as they still have 7 day cloud storage. For Essential you need a subscription for cloud recordings to see clips in the App.
How do I set up local storage backups on a USB device using my Arlo base station?
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
