- English
- Cameras
- Re: Is there a way to manually trigger Alarm on Ar...
With the Arlo Pro 2 Base Station one can trigger the built-in alarm. Which is always good to perform a quick test or in case of need (emergency ?). I can't find a way to manually trigger the built-in siren of the Arlo Essential Indoor Camera. Do I miss something ?
Use the red "shield" at the top of the app to start the process. Then choose the indoor camera as the one to activate. You would do the same thing for the base.
Works thanks ! Was assuming the choice of device would come sooner. Funny noise 🙂
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
