- English
- Cameras
- Is there a base station that would work with both ...
I have a VMB3010r2 base station with H7 cameras. I bought 3 new Arlo Essential Cameras. It appears my old base station wont work with my new cameras. Is there a base station that would work with both my old H7 cameras and my new Essential Cameras?
First, you can connect the essential cameras directly to your home wifi (w/o the base). You'd lose local storage, and wouldn't have the ability to control all cameras from a single mode.
But to answer your question, the compatibility list is here: https://kb.arlo.com/000062284/Arlo-SmartHub-and-Base-Station-Compatibility
Note the essential cameras (unlike your old ones) don't include free 7-day cloud storage. So you will need a paid subscription after the trial ends if you want storage.
If you get new base, get a smarthub (VMB4540 or VMB5000). Both give you the option of direct access to local storage ( https://kb.arlo.com/000062337/What-is-Direct-Storage-Access-and-how-do-I-use-it ). That doesn't require a subscription, but has several limitations
- Access to recordings only in the app (not the browser)
- Access to recordings only using the primary account (not friend accounts)
- No manual recordings/snapshots
- No thumbnails
- remote access requires router configuration, which some find difficult.
Stand-alone bases are hard to find at the moment (and often are overpriced).
- No thumbnails
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
