Is the Arlo Essentials camera compatible with Arlo Pro 2
  • 1 Reply
  • 2341 Views
ErikJohnson
Question, is the Arlo Essential compatible with an existing Arlo pro 2 system, meaning can I go into my existing base station (through the App) and add this camera?
Thank you,
dcfox1
Yes, if you have the VMB4000 you listed. You can check what cams are compatible with each base/hub.
What is the difference between each Arlo SmartHub and base station?
