Is Arlo Essential Spotlight compatible with VMS3530 hub?
  • 1 Reply
  • 1337 Views
westchesterca
I have a five camera VMS3530 system and I want to add another camera.  The Essential Spotlight is intriguing and I want to know if it is compatible with my system before I purchase.
dcfox1
The essential will connect to any base from the VMB4000 and up, not the VMB3000 series base. but you can connect the Essential directly to home wifi without a base but you need a subscription for cloud recordings though on newer cams.  This is the list of compatible bases/hubs.
What is the difference between each Arlo SmartHub and base station?
dcfox1
