- English
- Cameras
- Re: I have a vms 3530 system. Is there a camera t...
have a vms 3530 system. Is there a camera that is compatible that has two-way audio. Have 5 cameras but no audio
You can use the Pro or Pro 2 cameras for audio:
https://kb.arlo.com/000062284/Arlo-SmartHub-and-Base-Station-Compatibility
You could also use Essential or Pro 4 cameras - they aren't compatible with your base, but you can connect them directly to your home wifi. These would require a subscription though, as they do not come with any cloud storage.
Note there is a 5-camera limit on the free 7-day cloud storage you have now. So if you do add a Pro or Pro 2 to your system, you will need to remove one of the cameras you have now (which must be the original VMC3030 with the 4 CR123 batteries).
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
