  • 4030 Views
ArloPro3
As per the pictures, the VMA5600 solar panel has a magnet and three pins in a triangle while the base of the camera has a USa 20201229_134212_resized.jpg20201229_134153_resized.jpg
USB port. So how does the solar cable connect to the camera?
ArloPro3
The two devices are not compatible. A different model solar panel is required
ArloPro3
JessicaP
Hi ArloPro3,
You will need to use the Arlo Essential Solar Panel (VMA3600) to use with the Arlo Essential Wire-Free Cameras.
Yu51481
The amount of energy that the solar panel can produce is affected by how much sunlight the Connect the other end of the cable to your Arlo camera.
