- English
- Cameras
- How can I connect my Arlo Essential Spotlight cam ...
How can I connect my Arlo Essential Spotlight cam to my VMB4000
How can I connect my Arlo Essential Spotlight cam to my VMB4000 Base station? According to both devices, they are compatible with each other. I also followed the instructions to remove and add camera but it only connects to our home network/ wifi. Am I missing a step? The camera is working on my app but will not capture recordings since I’m not subscribed to Arlo cloud. Thank you in advance
There was a suggestion in a different thread to try using the web client (my.arlo.com) to see if that helps.
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
