Essential
  • 11 Replies
  • 1522 Views
Mick47
Gday
Have gone from my old network to starlink wi fi and want to connect my cameras to that .
Old network has finished.
I enter the new wi fi credentials and continue the usual way[QR code] and my cameras cant be found.
I go back and try again and the old network is still listed...cant find cameras with no connection .
Try to connect again...put in new starlink and password...goes round and around.
Pls help
Mick
Tasmania
11 REPLIES 11
Did you remove the cameras from the account?
Assuming yes, then try using the hardware reset (hold down the pairing button until the camera LED flashes amber - about 15 sec).
If they are still in the account, then try setting up the Starlink wifi to use the same network name and password as your old network (generally the easiest thing to do when switching ISPs).
BrookeN
Please try not to double post. I responded to your other post already.
Mick47
Didnt remove cameras from account
i dont know how to change SSID and password on Starlink
I hAVE 6 devices connected to my starlink...just need to connect these cameras.
I have used old TP LINK password as advised...makes no difference...cant find cameras
Why get an option to put in a new network if it doesn't recognise it?
I do a factory reset
I only rarely get flashing blues lights...when i do i occasionally get a chime.
It then searches for the cameras to no avail.
Mick47
Have contacted starlink and changed my camera setting to 2.4ghz
Now i just need these cameras to flash blue....but they never do
help
https://starlink.com/bb/support/article/84fa18cf-758c-6fee-98e7-756d75d6f811
Then one option is to
  1. remove them from the account
  2. do the hardware reset by pressing the pairing button until the camera LED flashes amber (about 15 sec)
  3. reinstall them
Note if you already reset the cameras, this is the only option.  You have to remove them from the account and reinstall them.
Of course that would only work if the old wifi network were still up and running.
The change network feature can be useful - for instance, many people will set up wifi extenders to improve coverage, and those often use a different SSID.  Another scenario is when people want to shift their cameras to an iOT wifi network (still keeping their main network up and running).
Mick47
I have removed my cameras from my device.
I went to reinstall and cannot get blues lights
The cameras are fully charged
Try the hardware reset again - holding down the pairing button until the camera LED flashes amber (~15 sec).
Mick47
Are you for real???!!
I have reset the cameras multiple times and when I go to set the camera I only get AMBER.
I can only go by what you tell us here.  And this is first time you've said that.  You've only said you weren't getting blue.
Mick47
Crap ..go back to message 7 23/6..clearly says I'm not getting blue.
Read my posts.
Can you help me or not?
I saw that.  But "not getting blue" is not the same as "stuck on amber".  Usually folks saying that mean there is no LED lit.  Do you actually mean the LED stays lit on Amber, and does not turn off?
I don't work for Arlo, and don't have any advice if the camera LED sticks on amber.  One cause in their KB article is a low battery, but you have said you've fully charged them.  That said, if the LED is stuck on amber, then you won't get a fully charged indication (since that is a solid blue LED).
