Essential spotlight vmc2330. After battery charge, auto spotlight on function not working.
  • 1693 Views
goldwheels
After battery charge, auto spotlight on function not working. I can operate it manually. I've turned everything on/off but it doesn't help, any ideas?
ShayneS
Are you trying to use the spotlight in the day or night? You can try recreating your modes or turning your mode to Disarmed & back to Armed, You may need to try and factory reset the camera if these steps fail.
goldwheels
Hi Shane, thanks for reply.
The spotlight not working issue is at night. I've tried disarming to no avail.
I'll try the modes.
I've deselected one of the cameras and then tried to reselect it, but now the app can't find it at all, so I'm down to 2 cameras.
How do I factory reset please?
ShayneS
You can find more details on that here: How do I factory reset and re-sync my Arlo camera?
