- English
- Cameras
- Essential spotlight vmc2330. After battery charge,...
Essential spotlight vmc2330. After battery charge, auto spotlight on function not working.
After battery charge, auto spotlight on function not working. I can operate it manually. I've turned everything on/off but it doesn't help, any ideas?
Detección de Movimiento
Are you trying to use the spotlight in the day or night? You can try recreating your modes or turning your mode to Disarmed & back to Armed, You may need to try and factory reset the camera if these steps fail.
Hi Shane, thanks for reply.
The spotlight not working issue is at night. I've tried disarming to no avail.
I'll try the modes.
I've deselected one of the cameras and then tried to reselect it, but now the app can't find it at all, so I'm down to 2 cameras.
How do I factory reset please?
I'll try the modes.
You can find more details on that here: How do I factory reset and re-sync my Arlo camera?
Arlo Essential Spotlight
Bevor Sie kaufen
receipts
totally frustrated
VMC2030
VMC2030-100EUS
