Essential smart wire-free door bell. With 2 chimes
  • 1 Reply
  • 1195 Views
Haagendas
Hi. I am just about to buy a wired free essential door bell that comes with a chime. Can anyone advise whether I can use the wireless chime and also my existing hard wired chime so I have 2 that go off in different parts of the house when someone presses the door bell or can I only have 1?
Did you actually mean the AAD1001 (audio only)?  Or did you mean the AVD1001 (which has a camera)?
Most hard wired chimes are compatible, so the doorbell should activate the hard-wired chime when the doorbell is pressed.  You can also use the Arlo chime in addition to the hard wired one.
You do need to double-check that the current system uses low voltage AC (16 volts - 24 volts), and that the transformer has at least a 10 VA output.
