- English
- Cameras
- Essential camera spotlight staying on and not reco...
As time progresses I will need to turn off the camera more often until I have to restart the base along with the camera. When restarting the base no longer works I then need to remove the device and re-add it.
Curiously the other cameras used to suffer a no recording phase but live view still working issue but have not had this on them in a long time.
The XL states no updates are available.
Very annoying, my essential xl is under warranty for another month, if a resolution isn’t found I shall return it and leave appropriate feedback.
Thank you
SuTzu,
The symptoms you describe could be related to a connectivity issue. Connecting directly to WIFi is certainly worth trying, if you have the option.
SuTzu,
Is the signal strength weak for this camera? How far away from the router/base station is it and are there any other nearby devices that could be causing WiFi interference?
Our wifi router is at a similar height about 5 meters away.
Thank you
SuTzu,
Apologies for the late reply, I was away for easter holidays. I have no removed it from the base station and connected directly to wifi so will monitor it's behaviour over the next week. Cheers!
So far I am seeing battery level updates and haven't yet had the spotlight stuck on issue, it could be the newer XL's require a strong signal to wifi unlike the older arlo 2 pros.
Appreciate the advice and will mark as the solution
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
