Ive connected my wireless door bell to my traditional digital chime but it only works once. I have to disconnect it from the wall bracket, re-connect it for it to only work once again. Any ideas would be appreciated.
What is the voltage and amperage of the transformer?
It is 230v - 240v AC and 12v
12 vac must be the output voltage - that is within the specs of the AVD2001.
Have you checked that traditional digital chime is enabled in the AVD2001 settings?
Yes the traditional chime setting was enabled. It worked once and then didnt work again until i removed it from the wall and set it back up again.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
