Cannot connect my essential cameras to my wif
  • 2 Replies
  • 1869 Views
  • 2 Likes
Kimjo
I cannot connect my essential cameras to my wifi, I got 1 connected and it went offline and couldn't reconnect. My question is the base station needed?
Not needed but may help. First, remove any problem camera from your account, use the reset procedure on each and then onboard again. Try onboarding with the cameras near the router and then move them to the needed locations. If then a problem it would seem to be a signal strength and/or quality issue.
Kimjo
K thanks I did all the things I did before and this time it worked. Thanks for the help
