Can you turn Arlo Essential outdoor camera off
  • 2 Replies
  • 2920 Views
Pipp
Hi,
I'm looking at buying an arlo essential outdoor camera but I would like to know if it can be turned off. I appreciate that with the modes you can change it to a mode where it won't alert about motion but I would like it to to not to record or be available for online view while I am at home. (essentially I would like it to be completely off, some kind of standby mode)
Also does anyone know about about the integration with SmartThings, can mode be changed from the SmartThings app?
Thanks,
And for further clarification, if the camera is not included in a mode, it's disarmed. That's where multiple custom modes are useful and then use the schedule and/or geofencing to switch to a mode which does not include particular cameras. However, that doesn't preclude being able to use live view and manual recording. If that's imperative, you would have to use the On/Off toggle for the camera in its settings manually each time (don't forget to turn it back on).
Otherwise, the Essential indoor camera would likely be your best bet, as mentioned above. Without using the On/Off toggle, the privacy shield would be closed. Live view is still possible but requires an authentication step to activate it which may be adequate.
Just to clarify - you can also change it to a mode where it won't record when motion is detected.
There is a device on/off control in the app for the camera.
If you are thinking about indoor use, you might consider the Arlo Essential Indoor camera, which has a privacy shutter.  It does require AC power, but if you can arrange that it is a good option.
