Camera Choice
I am looking at moving away from Outdoor Nest Cam as it’s such a poor quality camera.
I’m not familiar with Arlo so all help much appreciated.
There are so many models to the outdoor Arlo & I’ve been told it does not need plugged in either , all wireless with a battery ?
Most Arlo cameras are battery-operated. Those that require AC power are for indoor use only.
You can use arlo.com to select and compare cameras to see what you want/need as well as to compare price. The lowest cost ones are the Essentials followed by the Pro 3 and 4 and then the Ultras. SOme cameras can connect directly to your WiFi (Pro 4 and Essentials) but I tend to suggest a system that includes a SmartHub since connection problems seem much less than those connected directly to WiFi. All of these will require a subscription for cloud recordings once the 3 month trial subscription for each camera runs out.
Hey @RizXperia
Hopefully we can bring you over to the Arlo family : )
Let us know if you have any further questions and We will be happy to assist.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
