Battery won’t charge
My camera’s are 2 years old This is the second one of 4 that won’t charge! I bought 2 new chargers & still no luck I tried resetting , removing device & re-adding Any other suggestions? I can’t get anyone from support to call me back!
Message 1 of 2
324
WHat does the camera LED show when power is first applied? It should briefly blink blue indicating power is applied. If so, try this procedure - the key is to plug in and unplug many times to get enough charge into the battery to then allow it to charge normally:
https://kb.arlo.com/000052305/My-Arlo-Pro-or-Arlo-Pro-2-battery-is-dead-what-do-I-do
If this fixes things, charge proactively - don't let it run completely out.
Message 2 of 2
315
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
