- English
- Cameras
- Arlo essential wireless doorbel won’t connect
I’m trying to install my doorbell and it won’t stay on or connect. It’s fully charged but will not stay on long enough to connect
Have you reset it? What do you mean by it won't stay on long enough? It isn't supposed to turn off at any point. Are you setting this up near your router or by the door?
When I install the battery the LED lights will flash and after 2-5 minutes it will shut off. I am setting it up next to my router also
Are you saying you can't get past the QR code before it shuts off?
Or something else?
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
