Hi can anybody help I've had to reinstall my camera from the beginning and reinstall the app
I'm not able to connect now to my fone going through the set up it does qr and chimes flashes blue for 3mins then flashes orange then nothing
Sorted had to change WiFi passwords on router
Did you remove the camera from your account? That's needed to then be able to set it back up again. You may also want to try the reset procedure:
https://kb.arlo.com/000062438/How-do-I-factory-reset-and-re-sync-my-Arlo-camera
Ive done a factory reset hold sync bottom for 15sc blinked orange afterwards started the set up and with the same result at the end no camera found
I have my account I can see my monthly payments but i can't add my camera to it as I did before the problem it seemed easy when I first installed the camera last year now it's a nightmare
That didn't answer my question as to whether you have removed the camera from your account. Especially after resetting the camera, it must be removed from the account before it can be added back in.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
