- English
- Cameras
- Re: Arlo essential spotlight factory reset itself ...
Arlo essential camera did a factory reset on it's own, I reconnected it and it lasted 5 minutes before it reset again. Took it down and tried to reset it, but the only lights that I could get were the infrared lights to flash and it was clicking. Now there is nothing.
Is it still covered by the warranty?
Should be, I'll have to look up when I bought it. I have 5 of them, will I need a serial number?
Warranty is 12 months in most places. If you have Arlo Secure Plus in Europe, then it would be 2 years.
No idea, I haven't needed to do a warranty return myself.
Please read through the following link for what you will need for a warranty replacement.
https://kb.arlo.com/000062236/How-do-I-request-a-Return-Material-Authorization-RMA
I've already talked with support and have a case number, they have sent the information to the engineering team.
Case number 43745740
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
