@JT002 wrote:
I can live stream and I can manually record and manually turn on spotlight.
Ok. And you are getting notifications from the camera, so you know it is triggering.
I think the next step is to take another look at the rule for this camera in the mode - making sure that the "Record Video" is checked in the "Then do the following" section. You might also try switching to "armed", and seeing if that works differently.
If neither of those resolve the problem, then you should probably contact support.
What is your active mode? Have you tried creating a new custom mode with appropriate settings as a test?
@JT002 wrote:
It is a custom mode. I have it set to record when motion is detected. The setting mirrors my doorbell camera settings. I also realized last night that the spotlight did not trigger and it is enabled on constant mode. Still getting notifications, just no recordings or spotlight.
Can you live stream? Have you tried making a manual recording?
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
receipts
totally frustrated
VMC2030
VMC2030-100EUS
