Arlo essential only 1 that is showing up in the library.
  • 4 Replies
  • 2324 Views
Willhunting264
I have 4 Arlo essential cams. There is only 1 that is showing up in the library. Other cams are detecting motion. Shows there is something in the library but there isn’t. They are connected to WIFI, not the base. Help!!! I still have the base on and running.
Any camera newer than the Pro 2 absolutely needs a subscription for cloud recordings.
If they're not connected to your base, it doesn't matter if the base is on or not.
First, does this camera have a subscription? Next, check the library and verify that no filters are set.
Willhunting264
Shouldn’t need a subscription. But no it doesn’t. And there are no filters on.
Willhunting264
Well that sucks. Thanks
