- English
- Cameras
- Re: Arlo essential not recording unless armed? He...
I adding the Arlo hub monitored security system to my home so now I have the hub. I’ve also added the door sensors. Those all work great as does my doorbell that I had prior. BUT my indoor garage camera and outdoor essential camera, however no longer provides any type of notification or records any activity unless the dang alarm is armed! I know there’s a lot of feeds about this being a common issue, but I don’t see a current solution?!! Why is this a problem I need help it seems silly that this is an issue? Help I need a solution! #essential wireless
The security system works in conjunction with the cameras so if the security hub is in a disarmed state, the whole system is disarmed. That's expected behavior.
You can modify Standby so it keeps those cameras armed.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
