Arlo essential does not record
  • 13 Replies
  • 4257 Views
  • 8 Likes
Arloissues2023
I have an Arlo essential that does not record video, although it detects it. I have spent days workkng with Arlo support and they still do not have a solution. I have completed all recommended troubleshooting steps. The camera is connected to the Arlo base.
Did anyone have this issue too? Did you figure it out?
13 REPLIES 13
Is the camera in a subscription plan?
Can you make a manual recording when livestreaming?
Joelleb
Bonjour,
J'ai exactement le même problème.
J'ai tout réinitialiser...
Rien ne se passe .
@Joelleb wrote:
Bonjour,
Rien ne se passe .
same questions for you.
  • Is the camera in a subscription plan?
  • Can you make a manual recording when livestreaming?
Joelleb
Bonjour
J'ai un abonnement depuis 3 ans .
Je ne sais pas comment enregistrer manuellement
When you live stream the camera, you should see a record icon in the center at the bottom (it looks like a target).  Press that, and it should make a manual recording.  That confirms that your camera is in the subscription plan.
Joelleb
Je n'ai pas ce bouton .
Pourtant j'ai bien un abonnement....
Le mode de ma famera indique : ne rien faire ....je ne peux pas changer ce mode....
Il y a donc un problème avec mon abonnement..je suis pourtant facturée....
Have you gone into the subscription settings, and double-checked that the camera is in the subscription plan?
If you use an iphone, you will need to do this on a PC (logging into my.arlo.com).
Joelleb
J'ai regardé et ma camera est bien dans le plan d'abonnement.
J'ai joint le service clientèle et ils ne comprennent pas....ils font des recherches....
Arlocamissues
Thanks for your response. So, this camera type can only record if I buy a subscription?
Arlocamissues
Cannot record locally. Someone else me tioned the subscription so it sounds that is the only option for this camera type.
Basically yes.
You only get cloud recordings with a subscription - that's true with all of the current Arlo cameras.  Legacy cameras have 7 day free cloud recording, but Arlo stopped offering that with new models about 5 years ago.
You can get local recordings if you get an Arlo smarthub (VMB4540 of VMB5000), but the subscription offers a better experience.  IMO the feature is more suitable for backup.
  • Local recordings are only shown in the app, not the browser.
  • Local recordings cannot be shared, so they are not accessible from a "friend" account.
  • No ability to make a local manual recording or snapshot
  • No thumbnails - all recordings need to be downloaded to your phone before you can view them.
  • Remote access requires router setting changes that many find difficult, and which won't work with some internet service providers.
Arlocamissues
Thanks so much for the info. I can’t believe 4 Arlo support prople did not mention this!
Joelleb
Ça y est !!
Ma camera Arlo peut de nouveau enregistrer !!
Il paraît qu'elle était déconné et que seul un responsable chez eux pouvait la reconnecter !!!
Il aura quand même fallu attendre 5 jours pour !!!!
