Arlo essential cameras
I’m looking into purchasing 3 essential indoor cameras. Will be using my existing net gear WiFi. Plan to purchase the subscription.
I’ve read many of the ?’s on this site but before purchasing I want to make sure I have crossed my t’s and dotted my i’s.
Is there anything I should be looking at before making this purchase.
Thank you I’m advance!
I have one connected to my Netgear Orbi system, and have had no issues with it.
How are you planning to use it? You hopefully are aware that livestreaming can only be done for about 30 minutes - then the stream will stop.
Stephen, no I did not know that. Are you saying it only livestreams 30 min at a time and then has to be reset?
I had planned to use it inside
my house for anyone that may enter through a garage door and such.
Yes, the livestream will time out after about 30 minutes.
Okay.
thank you for taking the time to give me your feedback.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
