One of my Arlo VMC2030 cameras stopped working and doesn't respond when trying to reset it. I plugged it into the charger, but it gets onto a close loop cycle where the blue LED turns on for a few seconds and then red LED lights flash with a corresponding double click noise. And that sequence continues until the battery dies. No response when I press and hold the sync button. Any suggestions on how to reset the camera? Thanks
Use Settings, Support (Center) to select your camera model. Scroll down to Contacts to talk to official support. This requires a subscription.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
