Arlo Essential wire free. motion detection issues, battery drain, etc.
  • 1425 Views
wbush98h
I have had this essential camera for almost 90 days. I'd say it works 30% of the time. I restart all the time, and reconnect to my wifi. No help, still doesn't pick up motion nor records when I'm standing right in front of it. It's been 3 days since it's recorded anything. It drains my battery as well. So frustrated. My signal strength is good. When I go to live view, perfect every time, no issues. Then I close the app, walk in front of the camera and nothing is recorded! WTH
Signal strength isn't the only issue - there's quality, too. Another wireless device using the 2.4GHz band can interfere with the connection, too. Have you tried moving the camera closer to the router or base/hub, depending on how it's connected, to see if that makes a difference?
wbush98h
I only have my laptop connected to the router and most of the time it's shutoff. The router is approximately 8 feet from the outdoor camera with only the exterior wall separating the two.
Do you leave the camera armed all the time?  If not, are you using scheduling or geofencing?
Are you able to reliably live stream the camera?
Do you have activity zones enabled?
Have you tried the motion detection test?  https://kb.arlo.com/41/How-do-I-change-the-motion-sensitivity-on-my-Arlo-camera
