- English
- Cameras
- Re: Arlo Essential spotlight keeps factory resetti...
Ive used my arlo camera for a few months and it worked until 15 days ago when I looked on my app and the camera was not linked to my account anymore. It took me 15 days to get the time to climb my way up there to factory reset it.
It worked again for 2 hours until I got a notification on my phone that my camera received a factory reset signal.
It has been removed from my account again.
What or who is sending my camera a factory reset signal and how can I stop this. Nothing I search online is helpful or remotely relevant. Arlo support is completely useless.
Best answers
Many of the cases that have been reported that result in the symptoms being discussed here include damaged or improperly seated charging cables/solar panels. Third-party accessories have also been known to result in the symptoms discussed in this thread. For those experiencing these symptoms after having ruled out a third party accessory or damaged charging cable/solar panel, I encourage you to reach out to Arlo Support to further investigate the issue. You can find Arlo Support contact options within the Arlo Secure mobile app under Settings > Support.
Well, the good news is that I’m not alone 🙂
I’ve had this problem going on for nearly a year now, when I was forced to switch to the Essential Spotlight cameras because Arlo was discontinuing support on our older Arlo cameras. Since we installed the five new Essential Spotlight cameras, we have had this issue happen two or three times, in less than one year. First, the camera will just drop off of the network. Sometimes I can get back on, sometimes I can’t. I’ve had to return two “bricks” that would not sync or allow me to even set it back to factory, no matter what I tried to do.
Now here’s the clincher that might help somebody, maybe even Arlo if by some miracle they are actually paying attention to these Community posts…the issue keeps happening on the same named camera, even after I replace it. All of my other cameras are fine and have never had this issue. Only the one that I keep putting in the same place and giving the same name. I would say maybe this is weather or moisture related, if I didn’t have several other cameras installed under the same conditions. It is an outdoor camera, right? 🙂 I’m waiting on my second replacement now, when that shows up, I’m going to give it a completely different name, maybe it’s as simple as that.
I personally do not believe that this issue is being caused completely or even partially on the camera end. I believe that is a software or back end Arlo software or server issue. And since Arlo or whoever owns them now really doesn’t provide communication with customers here, and are generally difficult to work with on technical issues (i.e. “have you tried rebooting” etc. :)), we are basically hosed.
I’m hoping that renaming a new replacement camera will solve my problems. Otherwise I’m ripping Arlo out and moving to any number of other great solutions with great support out there. I’m tired of years worth of trying to fix Arlo’s issues for them, without any involvement from the company itself. That’s complete and utter BS, sorry.
I will provide another update at some point. Good luck!
This just started to happen to me last week on a Pro 4 with Arlo solar panel…
Looks like this thread hasn’t been updated in a while. Any known fixes out there?
Of the multiple Arlo cameras I have this is the only one that has full exposure to the elements…I guess my question is which is gone bad? The camera? Or the solar panel and cord?
Yeah I posted here a while back but kept being subscribed too see what else was out there. Mine too was pro 4 with solar panel all arlo. I was the one who had house waterblasted when my issue came up. I've still not had the issue return personally so I'd suggest (hopefully easy accessible) but pull it down only camera and open housing remove battery and leave it near a dehumidifier or put it in a bag of rive and leave it in ur cupboard for a day then clean the connector on camera for charger and also clean solar charger connector then if it's anything like mine u reset it manually and then re add the camera and that should b all to do but I'd suggest to either get a cover or something as im pretty sure the issue here is most likely water ingress but each to their own! Hope that helps annoying yes but hope it least fixes it so u don't have to spend extra money just yet, I can't even remember when I posted but you can search it in this thread from then till now it's never done it again but all mine are under a little part of roof so not exposed exposed apart from when the guy tried to clean them and the wall they attached to with his commercial water blaster. Just glad I got it sorted so good luck
Well followed the above advice and it worked this time for about 20 minutes…
So - If I replace the camera with a new one would I likely solve the problem?
Camera replacement has been the only strategy that has worked for me.
I’ve had another thought on this one, going to spend the $22 or whatever and see if it makes a difference.
SDS DS-1250ZJ Universal Sun Rain Shade Camera Cover Shield Cover Shield for Nest/Ring/Arlo/Dome/Bullet Outdoor Camera (1 Pack, White) https://a.co/d/glYiNsa
Well I bit the bullet and replaced the camera with a new one…
it does the same thing. Works for a couple of minutes then I get a factory reset notice and the camera disappears from my dashboard.
It might be time to walk away from Arlo 🥺
I have 9 essential cameras. over year and half. The problem is they leak. The housings are not water tight. Water gets into the reset switch which is the lowest part of the camera, and the water mimics holding the button for 15 seconds. This sends the camera into reset mode, and you get the message. and it deletes it off your phone. I had one that was so wet, it took 3 weeks next to the heater to dry and function proper again. You do have to take the housing off of the camera and set the guts next to a heater. Pretty simple really. The water does not dry easy, it takes time. I have one dry for 3 days and now that one will pair and last 24 hours before doing the factory reset. Letting it dry more. I dont use solar panels or have any wires attached outside. I bring them all in for charging. This is simply a water getting inside the case issue period. I had water dripping out of the last one, when I tore it apart. Case was in perfect shape. One that I had issues with had tree squirrel or rats chewing on it and broke the speaker screen. Cant blame arlo for that one. This last one is just a leaky case. The other 8 cameras are still working fine. all exposed to the elements
I had 2 more go out at the same time. One of which has never been outside so for me I don’t think it is a moisture problem. I cancelled my service.
Also I know someone else who had 2 go out about the same time as my first one went out despite theirs being 1 year newer than mine. They were outside but mounted under eaves so not in direct rain. They canceled also.
I’ve come to the conclusion that the “factory reset” issue is related to the Arlo solar panel…
Both of the cameras (one older and one new) work fine on my other solar panels. When I attempt to attach the one panel I’ve seen as part of the problem to any camera it almost immediately triggers a factory reset on any of my Pro 4 cameras I attach it to.
Other Arlo panels work fine on these same cameras.
I'm having the exact same issue with the Arlo Pro 4 camera. I also believe it's related to the Arlo solar charger. After setting it up, I can leave it for hours, even plugged in to a wall charger. Then, as soon as I connect the solar panel, I get the message that the camera has received a factory reset request.
My dead unit was plugged into an AC charger, under a roofline, with cover over it.... and functioned to the factory specifications until the software upgrade.
I have the Arlo essential cameras. One is going into fits and sending the factory reset notification and removes the camera. I try to add it back and the sync button doesn’t respond. After a few minutes it starts blinking and I can add it back. It doesn’t stay up 5 minutes and I get the factory reset notification again and it’s removed. When I called Arlo and spoke with Mac he said I had to pay $138 subscription charge and $75 to update the software. My other camera works fine. I’m at a loss here.
Do you have the camera attached to a solar panel?
You didn't call Arlo - you reached a scam support site. Likely that was a result of googling for a phone number.
Hopefully you didn't pay him (or give him any personal information - account passwords, etc).
There is a known issue with some cameras generating factory reset messages. I think Arlo is still investigating. If you want to try real Arlo support, then use the app to get it. You can get phone support between 6 am and 6 pm US pacific time if you have a subscription. I'm tagging the mods ( @JamesC , @ShayneS , @BrookeN ), as they can help you connect with support.
I have a Arlo essential spotlight camera that sent me a notification onto of my cameras recently about factory reset. They are no longer in my list of devices.
Mine bricked this week also. Must have pushed a new firmware update that killed it. I’m switching brands
One of mine bricked this week too. It keeps trying to reset its self everytime I re-add it. I already had one brick before that, sent it back to them because they said it was defective, and another new one they sent me bricked too. My mother at another house had one of hers brick too in the last month.
I think you’re right and there should be a class action lawsuit for a poor product. There is just too many people having the same issues for it to be our problem.
The last thing I was told is to charge the cameras for around 4 hours, and then try to press the button and wait for the blue light, that is what I am doing.
I have the Arlo essential and it’s doing the same thing. Auto factory reset and it removes itself from the account. Fun times.
Yes, it has happened on two of my Arlo essential with spot light. I’m done with this. No urgency at all from Alro. Too many options out there now to have to have issues like this. Time to cancel subscription and move to a more reliable option.
I have 3 of these Essential spotlight cameras, they all came in one package.
Two of them are fine, I have one hooked to a solar panel and it's had no issues. The other two are in lower activity areas and I have no panel for them, I just charge every couple months, less if activity increases.
A few days ago one of them gave me the factory reset. I took it down today and relinked it, only for it to reset itself before I could finish setup.
Obviously reading through this thread I realize it is NOT a water issue, it is a software issue.
Worst part is that it not only clears the camera, but also ALL of the events. What if I was out of town when this happend and needed to access my events. This is UTTERLY unacceptable.
If I can't get this to work I should still be in the warranty period I think for a replacement. Hopefully they can figure out why they are bricking people's devices before we move on from Arlo.
- I have been having issues with my Essential Spotlight Camera constantly factory resetting. As its passed its warranty period, I decided to have a look myself. On taking it apart, I found that the unit has has moisture inside and carried part of the circuit board. I cleaning this off, ensured that the rest of the unit was dry then applied some silicone grease on the seals and closed the unit. It now works as before and does not reset itself.
- Not recommending that anyone else does this if they are still under warranty but it worked for me and I don't have to buy a new camera.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
