- English
- Cameras
- Re: Arlo Essential not recording. ‘Record video’ i...
I have an Arlo Pro 2 that is continuing to work and post videos to the library just fine, but all 3 essential cameras are acting this way.
I’ve reinstalled Arlo App
Rebooted base station
Toggled on/off each camera
No luck on anything - I missed a vital recording last night so I’m getting really aggravated.
It sounds like you don't have a current subscription. ANy camera newer than the Pro 2 has to have a sub to record to the cloud. If the Essential is synced to your base you can enable local recordings. However, depending on your base you may need to safely eject the drive to view on a computer. Only those bases/hubs starting with the VMB4540 can use the app to view the recordings without the need to eject.
All the newer camera Ultra, Pro3 on up require a subscription once the trial runs out. Only the Pro2 and older still have 7 day cloud storage. You should have received a 3 month trial with the essential unless it ran out.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
