With a solar panel connected, there's a new icon in use which is red with a lightning bolt even at night. If it's showing this and 100%, it's fully charged and working normally.
What have you tried? Have you disconnected the panel and plugged it back in? Have you checked the cable to see if it's damaged? Does the battery charge when using AC power?
Thank you. The icon is red so sounds like all is working properly
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
