  • 8 Replies
  • 3365 Views
Jet876
Base station wont sync to arlo phone app.
Jet876
Ok the link you sent helped it was not connected to the internet got it connected and it is now synced with the app. Just need to sync the cameras.
I had them long before i got the base so they will have to come down to be synchronized.
Is there a easier way to sync the cameras?
Thanks.
8 REPLIES 8
Streak2
Master Master
What base is it? Is it powered up and connected to the internet?
Have you added the base using your Arlo app connected to the same network as the base?
Jet876
VMB4000  and i have connected it directly to the router but it sync to the phone app
Jet876
But it will not sync to the arlo phone app
Streak2
Master Master
What color are the lights?
https://kb.arlo.com/000039100/What-do-the-LEDs-on-my-Arlo-SmartHub-or-Base-Station-mean
You did not answer the question about if you have actually onboarded the base to your app.
Jet876
I am seeing green blank space and orange
I am unable to o board the base to the app.
Jet876
Thanks.
Streak2
Master Master
OK well done.
You will need to have hands on the cameras in order to sync them to the base.
Jet876
Ok thanks much appreciated. i will try this weekend a d keep you posted.
