Arlo Base Station VMB 4500
My VMB 4500 base station suddenly stopped working with an amber flashing light. Tried factory resetting a number of times with no success. Any suggestions?
Thanks in advance!
Are you seeing it in the attached devices list in your router?
No, I am not seeing it on the device list but I do see the Arlo wireless SSID being broadcast. I’ve attempted multiple factory resets with no success.
Then it's not able to connect to the router using ethernet.
Have you tried a different ethernet port on the router? Or a different ethernet cable?
Ok, but you also need ethernet working, which doesn't seem to be the case.
Yes, I tried another device on the same cable and Ethernet port, it gets an IP address and 5he device is fully functioning.
Unfortunately, that likely means that the NIC on the base has failed. It's not repairable, so you'll need a new base.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
